Bsf Portb,0 Perchè Non Va?
Doohan
Ciao, ho un problemino con un "nuovo" pic....
	PROCESSOR	16F886
	RADIX  DEC
	INCLUDE  "P16F886.INC"
;	ERRORLEVEL	-202
;	ERRORLEVEL	-203
;	ERRORLEVEL	-207
;	ERRORLEVEL	-302
	__config	_CONFIG1,0010001111100100B
	__config	_CONFIG2,0011111111111111B
;-------------------------------- REGISTRI SU BANCO 0 --------------------------------
Count0  equ	20h;riservato per delay software
Count1  equ	21h;riservato per delay software
LCDTemp  equ	22h;...
AUX  equ	23h;...
	ORG     00h	;Punto di inizio del programma al reset della CPU
	goto	Start
;------------------------------------- INTERRUPTS ------------------------------------
	ORG     04h
	nop
	retfie
;----------------------------------- FINE INTERRUPTS ----------------------------------
;----------------------------- INIZIO PROGRAMMA AL RESET ------------------------------
Start
	bsf	STATUS,RP0;Seleziona Banco 1
	bsf	OSCCON,6
	bsf	OSCCON,5;Oscillatore a 4MHz
	bcf	OSCCON,4
	movlw	B'00000000';Prescaler che divide di 2 volte il clock su Fosc/4, destinazione Timer0, Pull-up abilitati su PortA
	movwf	OPTION_REG
;-------------------------------- DEFINIZIONE PIN I\O ---------------------------------
;PORTA
	movlw	B'00000000'
	movwf	TRISA
;PORTB
	movlw	B'00000000'
	movwf	TRISB
;PORTC
	movlw	B'00001000'
	movwf	TRISC
;PORTE
	movlw	B'00000000'
	movwf	TRISE
	bsf	STATUS,RP1
	bcf	STATUS,RP1;Seleziona Banco 1
;-------------------------------- PROGRAMMA PRINCIPALE ---------------------------------
	bcf	STATUS,RP0;Seleziona Banco 0
	clrf	PORTA
	clrf	PORTB
	clrf	PORTC
	clrf	PORTE
	clrf	AUX
	bsf	PORTB,0
	bsf	PORTB,1
	bsf	PORTB,2
	bsf	PORTB,3
	bsf	PORTB,4
	bsf	PORTB,5
	bsf	PORTB,6
	bsf	PORTB,7
MainLoop
	bsf	PORTC,2
	call	Tempo
	bcf	PORTC,2
	call	Tempo
	goto	MainLoop
;---------------------------------- FINE DEL PROGRAMMA ---------------------------------
;------------------------------------- SUBROUTINES -------------------------------------
Tempo  	;Delay software di 0,1 secondi
	return
;---------------------------------- FINE SUBROUTINES ---------------------------------
	END
Il lampeggio di MainLoop su PORTC,2 lo fa correttamente
la cosa strana sono i comandi:
bsf PORTB,0
bsf PORTB,1
bsf PORTB,2
bsf PORTB,3
bsf PORTB,4
bsf PORTB,5
bsf PORTB,6
bsf PORTB,7
se invece sostituisco gli 8 bsf ... con le segunti istruzioni
movlw B'11111111'
movwf PORTB
tutti i pin della porta B sono a Vcc...
Qualcuno sa spiegarmi l'arcano??
Se non ci sono errori nel programma, è probabile che dipenda da cosa hai collegato alla porta B. Nell'eseguire l'istruzione bsf PORTB,7 il pic legge le tensioni su tutti i piedini, modifica il bit 7 e poi riscrive il byte così modificato sulla porta B. Se per esempio sul pin 0 la tensione è troppo bassa la interpreta come valore basso (anche se l'avevamo messo a 1) e dopo l'istruzione bsf PORTB, 7 ti ritrovi il pin 0 basso.
Ciao
giacomo56+21/05/2010, 14:12--> (giacomo56 @ 21/05/2010, 14:12)
Grazie per la risposta ma non è così semplice: i pin sono scollegati, li vado solo a misurare con il tester ma 6 su 8 li trovo a massa invece che a Vcc...
se invece uso
movlw B'11111111'
movwf PORTB
funziona correttamente.
In rete ho trovato questo:
http://www.microchip.com/forums/tm.aspx?m=...=1&key=
Si, allora il problema è un altro. I PIC16F non hanno i registri LAT. Ho visto che sulla porta B ci sono gli ingressi analogici, disabilitali.
Ciao.
giacomo56+21/05/2010, 14:56--> (giacomo56 @ 21/05/2010, 14:56)
Quella degli ingressi analogici potrebbe essere....
ho guardato il DS.. in effetti i pin "cattivi" sono quelli dove posso avere anche ingressi analogici e al reset i pin vengono configurati come ingressi analogici...
resterebbe la stranezza del compostamento diverso tra il BSF sul singolo bit della porta B e la scrittura con il movlw --> movwf
