P.I. SCL per STEP7
walterword
questo è un file che ho scritto per regolare temperature
Si tratta di un regolatore P.I. con uscita anche pwm.
FUNCTION_BLOCK FB80           // Digital regulator P.I.D. Written by Walter P.  05/06/2009
VAR_INPUT
Set_Point:REAL ;               // Set point value
Feedback:REAL ;                // Feedback value process
Kp:REAL;                       // K Proportional gain
Ki:REAL;                       // K Integral gain
Max_Analog:REAL;               // Maximum value for analog output
Max_Time_Cycle:REAL;           // Maximum time cycle for PWM digital output (milliseconds)
Scan_Time:REAL;                // Scanning time of the plc
Time_Sample:REAL;              // Time sample in OB35
Enable:BOOL;                   // Enable PWM digital P.I.D.
Reset:BOOL;                    // Reset regulator
END_VAR
LABEL
salto;
end_label
VAR_IN_OUT
END_VAR
VAR_OUTPUT
Out_Analog_Reg:REAL ;           // Output analog regulation
Duty_Cycle_Perc:REAL;           // Duty cycle On percentage
Wave_On_PWM:BOOL;               // Output high wave On of digital PWM
Wave_Off_PWM:BOOL;              // Output low wave On of digital PWM
END_VAR
VAR_TEMP
END_VAR
VAR
Error:REAL ;                   // Error for each scan
I_Ist:REAL;                    // Istant
I:REAL ;                       // Integral memory
P:REAL;                        // Proportional component
Accu_Timer:REAL;               // Timer Accumulator for the duty cycle PWM
Thr_Wave_On:REAL;              // Threshold for the wave ON
Thr_Wave_Off:REAL;              // Threshold for the wave OFF
Wave_On:BOOL;                  // Wave On
Wave_Off:BOOL;                 // Wave Off
END_VAR
             BEGIN
              Error:=Set_Point - Feedback ;
              P:=Error * Kp * 1000.0 ;
              I_Ist:=Error * Ki;
              I:=I + I_Ist ;
              IF I <= 0.0 THEN  I:=0.0; END_IF;
              IF I >= Max_Analog*0.8 THEN I:=Max_Analog*0.8; END_IF ;
              IF Enable=true THEN
                  Out_Analog_Reg:=P + I ;
              END_IF;
              IF Reset THEN
                 P:=0.0;
                 I:=0.0;
                 I_Ist:=0.0;
                 Out_Analog_Reg:=0.0;
                 Wave_On:=false;
                 Wave_Off:=false;
                 Accu_Timer:=0.0;
              END_IF;
              IF Out_Analog_Reg >= Max_Analog THEN  Out_Analog_Reg:=Max_Analog;END_IF;    IF Out_Analog_Reg <= 0.0 THEN  Out_Analog_Reg:=0.0; END_IF;
              // STATE OF ENDED MACHINE TO GENERATE THE WAVE SQUARED ON AND OFF OF THE PWM
               Thr_Wave_On:= (Max_Time_Cycle / Max_Analog) *  Out_Analog_Reg;
               Thr_Wave_Off:=Max_Analog - Thr_Wave_On;
              IF  Accu_Timer=0.0 AND Enable THEN
                 Wave_On:=true;
                 Wave_Off:=false;
              END_IF;
              IF Wave_On=true THEN
                        Accu_Timer:=Accu_Timer +  Time_Sample;
                        Duty_Cycle_Perc:=(Thr_Wave_On / Max_Time_Cycle) * 100.0;
                        IF Accu_Timer >= Thr_Wave_On THEN
                            Wave_On:=false;
                            Wave_Off:=true;
                        END_IF;
              END_IF;
             IF Wave_Off=true THEN
                        IF Accu_Timer >= Max_Time_Cycle THEN
                            Wave_Off:=false;
                            Accu_Timer:=0.0;
                            GOTO salto ;
                        END_IF;
              END_IF;
              salto:
              Wave_On_PWM:= Wave_On AND Thr_Wave_On>= 1000.0;
              Wave_Off_PWM:=Wave_Off ;
END_FUNCTION_BLOCK
