CANCELLO FAAC 740 IMPAZZITO
SALVE,VORREI UN VOSTRO PARERE...
OGGI PRESSO UN CLIENTE HO RISCONTRATO QUESTO PROBLEMA SU UN IMPIANTO FAAC 740 CON RELATIVA CENTRALE 1-748 A BORDO DOPO AVER PRESO UNA BELLA BOTTA DA UN VEICOLO.
ANCHE SE SUL DISPLAY DELLA SCHEDA TUTTO FUNZIONA CORRETTAMENTE(IN FASE DI APERTURA,CHIUSURA,CANCELLO CHIUSO,CANCELLO IN PAUSA ECC) IL CANCELLO CONTINUA SOLO A MUOVERSI NEL SOLO SENSO DI CHIUSURA FERMANDOSI SOLO SE GIRO LA MOLLA DEL FINE CORSA DAL LATO OPPOSTO...
HO CONTROLLATO TUTTO,INVERTITO I FINECORSA,IL SENSO DI MARCIA, RESETTATO LA CENTRALE MA IL PROBLEMA PERSISTE...HO PROVAT A FAR GIRARE IL MOTORE SENZA CENTRALE E TUTTO E' IN REGOLA...HO DEDOTTO CHE SIA LA SCHEDA CHE SI SIA GUASTATA,SMONTATA E PRONTA X ESSER RECAPITATA PRESSO L'ASSISTENZA CHIUSA IN QUESTI GIORNI QUINDI VOLEVO APPROFITTARNE CHIEDENDO SE VI ERA MAI CAPITATO...
