Lavatrice Samsung Q1235 - Codice errore 8E
Dopo pochi istanti dall'accensione la macchina va in stop visualizzando sul display l'errore 8E che non viene riportato sul manuale di sitruzione (l'ultimo codice errore descritto dal manuale è il 5E).
Qualcuno sa forse di cosa si tratta?
Grazie mille a tutti.
ciao se ti puo essere di aiuto ecco i codici.
E1 - водна магистрала - WATER SUPPLY ERROR
- Water Supply Error occurs when water level frequency does not show changes more than 50Hz or water
is not supplied up to the water level presetting for 20 min or more at the time of initial water supply, the
error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2 - Източване - WATER DRAIN ERROR
- Ако показанието на ниворегулатора е 25.3KHz или повече in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E3 - Преливане - OVER-FLOW ERROR
- Over-Flow error occurs when the water level is in abnormal operation (OVER-FLOW: 22.40KHz/50Hz or
more). It can be cleared by turning POWER S/W OFF. Water is drained prior to POWER S/W OFF and it
is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected.
E4 - Дисбаланс - UNBALANCE ERROR
- Unbalance error is cleared by POWER S/W OFF and by resuming the POWER ON initial status.
E5,E6 - Нагревател - WATER HEATER ERROR
- In case the water temperature varies by 40°C or more in 5 min, or by 2°C or less in 10 min after heating is started.
- It can be cleared by turning POWER S/W OFF
E7 - Ниворегулатор - ASS'Y PRESSURE S/W ERROR
* Generated Frequency Signal of WATER LEVEL(W/L) S/W (KHz)
- If the same signal as the above table is detected for more than 5 seconds, it is a PRESSURE S/W Error.
- When the error occurs, perform the time-drain for 3 min and then turn off the water drain pump. Then the
display shows 'E7' as a pressure s/w error indicator.
Честота на изхода на аналоговия ниворегулатор:
Ниско ниво - под 30.00 KHz
Високо ниво - над 15.00 KHz
E8 - при неправилна температура за този тип пране - ABNORMAL WATER TEMPERATURE ERROR
- In case the water temperature is 60°C or more in the synthetic course, 50°C or more in the delicate
course, and 40°C or more in the wool course.
- At the time of initial water supply, if the water temperature is not appropriate, water starts to be drained
and it is forced to be drained for 2 min when the abnormal frequency of 25.24KHz is detected.
- Display shows 'E8'.
- This error can be cleared by POWER S/W OFF.
Course Water Temp
Synthetic 60°C or more
Delicate 45°C or more
Wool 45°C or more
E9 - изтичане на вода - Water Leakage Error
