Luca.Lombardi Inserito: 2 dicembre 2025 Segnala Inserito: 2 dicembre 2025 Dear all, I'm using Twincat3 on my laptop in order to test some devices with different fieldbus (profinet, profibus, ethercat, ethernet/ip...) and normally, even though my poor plc experience, all works properly. Now I'm testing a new device that use Ethernet/IP and is an adapter, so: I copied its EDS file into Twicat3/Config/IO folder Putted inside my project a scanner (TC3 EIP Scanner) Proceeded with scan operation. My device it was found and I add it into my list. With mouse right click, loaded the EDS file Append IO connection and I chosen Exclusive owner in order to send output and receive input Download this configuration in my plc (that run on my laptop) In realtime I see a strange condition The device ouput (that are input for plc) arrives correctly The plc output (that are input for external device) seems that doesn't arrive So I ask you guys...how is possible?! How is possible that the communication half works, meanwhile with other ethernet/ip works properly? Have you some idea? Thanks so much in advance
ALLUMY Inserita: 2 dicembre 2025 Segnala Inserita: 2 dicembre 2025 Excuse me, why did you wrote in english, when you are Luca Lombardi? 😁
Livio Orsini Inserita: 2 dicembre 2025 Segnala Inserita: 2 dicembre 2025 PLCForum è un forum orgogliosamente italiano! Si accettano solo discussioni e messaggi scritti in lingua italiana. Solo per i problemi relativi ai PLC esiste una sezione apposita in lingua inglese.
