Bryan K Inserito: 7 ore fa Segnala Inserito: 7 ore fa I’m looking for a copy of the old Selema / Vickers F1PC DOS software used with the F1 Formula / DBC III servo drives. The drive I’m working with is a Vickers / Selema 70-DBC-III-F18 on an older CMS CNC router with OSAI control. One of the servo motors was rebuilt, and I need to perform the resolver alignment / motor phasing procedure. The Selema documentation indicates that this was done using the F1PC software, through the drive’s RS-422 communication port. I have found references to: F1PC Rev. 2.2 F1PC Rev. 2.3 / Rev. 23 I would be interested in any version of F1PC that supports the F1 Formula / DBC III drives. I do not necessarily need an original floppy. Any of the following would be useful: F1PC installation folder F1PC.EXE ZIP archive floppy disk image backup from an old service laptop related configuration or support files SELINT-1 communication documentation If anyone worked on older CMS, Selema, Vickers, or F1 Formula servo systems and still has this software in an old service archive, I would greatly appreciate hearing from you. I am located in the United States and am trying to get this machine operational again. Thank you, Bryan
thinking Inserita: 45 minuti fa Segnala Inserita: 45 minuti fa Hi Bryan, You can try to contact this company, I don't know if they can . you: THIS
