Li 67 Duo Led Ammollo Lampeggiante
SALVE A TUTTI, LA MIA LAVASTOVIGLIE DOPO 10 ANNI DI LAVAGGI non PARTE PIU', CHIAMO IL TECNICO E DICE CHE SI E' BLOCCATA L'ELETTROPOMPA.... DICE CHE LA PUO' RIPRISTINARE CON UNA SOMMA RAGIONEVOLE....PROCEDIAMO E ALLA FINE DEL LAVORO LA MACCHINA PARTE REGOLARMENTE, MA AL MOMENTO IN CUI SCARICA PRIMA DEL RISCIACQUO SALTA LA CORRENTE E MI ACCORGO CHE LA CUCINA SI E' ALLAGATA, RICHIAMO IL TECNICO, DICE CHE SI E' ROTTO IL TUBO....PROCEDE ALLA SOSTITUZIONE E DICE DI NON ACCENDERE LA MACCHINA PRIMA DEL GIORNO DOPO POICHE' L'ACQUA PENETRATA POTREBBE FAR SALTARE DI NUOVO LA CORRENTE...OK!
IL GIORNO DOPO PROGRAMMO IL LAVAGGIO E DOPO POCHI SECONDI SALTA LA CORRENTE E NOTO DI NUOVO UNA FUORIUSCITA DI ACQUA DA SOTTO LA MACCHINA, STANCA DI RICHIAMARE L'IDIOTA, DECIDO INSIEME A MIO MARITO DI PROVARE A VEDERE DA DOVE ESCE L'ACQUA NOTIAMO CHE IL BO non E' FISSATO BENE, LO SISTEMIAMO E PROVIAMO A FAR RIPARTIRE IL LAVAGGIO..... PARTE, CARICA L'ACQUA E COMINCIA IL LAVAGGIO....MA DOPO POCHI SECONDI PARTE LA POMPA CHE SCARICA DI NUOVO, IL LED "AMMOLLO" COMINCIA A LAMPEGGIARE E LA MACCHINA SI BLOCCA... COMINCIO A SMANETTARE SU INTERNET E TROVO CHE MOLTO PROBABILMENTE LA RESITENZA POSTA SOTTO IL TUBO DI SCARICO E' ANDATA IN CORTO........UAAAAAAAAAAA!!!!!!!!!!!!!
CHE FACCIO ASPETTO CHE SI ASCIUGHI O DEVO RICHIAMARE IL TECNICO????
GRAZIE ANTICIPATAMENTE
